udf u1064 nmake
Old   September 6, 2007, 04:03
Default udf u1064 nmake
ali
hi all, i am trying to compile a udf using nmake command.i am doing each step given in fluent tutorial,but i got a error message as follow;
D:\>cd libudf\ntx86\3d
D:\libudf\ntx86\3d>nmake
Microsoft (R) Program Maintenance Utility Version 8.00.50727.42 Copyright (C) Microsoft Corporation. All rights reserved.
NMAKE : fatal error U1064: MAKEFILE not found and no target specified Stop
this is the first time that i used a udf and i can not overcome this problem.is there any other way to compile this udf or what can i do to solve to problem.
i would really appreciate if you could help me
Old   September 6, 2007, 05:38
Default Re: udf u1064 nmake
Joe
Try to compile a simple hello world type c program from a command line to verify that your compiler is correctly configured.
Old   September 6, 2007, 06:15
ali
thank you a lot Joe;
in this case error mesage is changed to;
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 8\VC\BIN\cl.EXE"' : return code '0x2' Stop.
Old   October 15, 2010, 11:32
asal
asaleghahreman is on a distinguished road
Originally Posted by Joe
;145139
I have the same error as Ali said.I dont understand how to solve this problem.I would really appreciate you if u could help me.
asaleghahreman is offline   Reply With Quote
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 18:05
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
udf compiling error concerning 'nmake' Violet Fluent UDF and Scheme Programming 6 October 23, 2012 06:27
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
