fluid structure interaction
Old   September 6, 2007, 11:21
Default fluid structure interaction
taru agrawal
Hi. I need some help about a CFD problem. I am doing a project, which involves the study of fluid flow effect on the surrounding boundaries and vice versa leading to a cycle in turn. This means that the CFD problem has the fluid flow and solid body motion solved simultaneously. The fluid flow influences the motion of the solid body, while the solid body motion influence the fluid flow. Can this be solved using any of the current available versions of FLUENT? Currently, I know that in FLUENT solver, the motion of the solid body is fixed arbitrarily and then we find the fluid flow field. But in actual situation, the fluid flow field will influence the solid body motion and in turn influences the fluid flow. I know that such an option is available in CFX but couldn't find any such thing in FLUENT.Please help me whether i can solve for fluid structure interaction (the fluid affect solid body motion, solid body motion affect fluid. But are solved simultaneously) using FLUENT. If yes then i would also like to know the procedure.
Thanks in Advance
regards
Taru Agrawal
Indian Institute of Technology, Kanpur
Old   September 6, 2007, 12:27
Default Re: fluid structure interaction
Joe
Can this be solved using any of the current available versions of FLUENT? yes
Do the tuts relating to FSI. Tut manual.
Old   September 6, 2007, 17:43
red lemon
yes this can be done with ANSYS FEA or ABAQUS using MPCCI from SCAI communicator.
Old   September 7, 2007, 16:56
JAI SHANKAR V P[
I AM JAI SHANKAR V P . I AM CURRENTLY WORKING AS SENIOR LECTURER WITH SNMIMT IN INDIA .I AM CURRENTLY COMPLEATING MY MASTERS IN PRODUCTION ENGINEERING WITH COCHIN UNIVERSITY OF SCIEANCE AND TECHNOLOGY , KOCHI, KERALA , INDIA
I AM VERY MUCH INTRESTED IN THE SUBJECT CFD
CAN YOU HELP[ ME STUDY THE SAME PLEASE MY EMAIL ID IS shankarvp@yahoo.co.in
with regards
jvp
Old   September 10, 2007, 03:12
Manoj Kumar
You can also try doing this using udf capability if you have just rigid body motion or simple structural deformations in your problem.
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 03:40
Fluid structure interaction tomm FLUENT 2 September 16, 2004 04:33
Fluid Structure Interaction Gabor Balint FLUENT 2 January 5, 2000 13:08
