how to create a large eddie
Old   September 6, 2007, 11:05
Default how to create a large eddie
Jonathan
Hello. I´m trying to see how a large eddie is broken in smaller ones by a turbulence grid. But i don´t know how to obtain a large eddie to broke it. I´m solving the problem in 2D
can someone help me to do this?
Thank you very much!
Jonathan
Old   September 6, 2007, 12:25
Default Re: how to create a large eddie
Joe
Vortex shedding behind a square cylinder at high Re.
Old   September 6, 2007, 12:29
Jonathan
Joe, thanks but could you explain it a bit more please? a square cilinder is just a square?
Old   September 6, 2007, 13:53
AAA
Hi
To my knowledge, RANS models such as k-e will only give you the average of the kinetic energy and dissipation. The only way to creat and analyze large eddies is by using the LES and the DES models (and of course the DNS). Those models can only be used in 3D and they have to be unsteady.
Try building a 3D model with an obstacle (i.e. a block) to creat the eddies.
Good luck
simpleFoam convergence on large domain kwiik OpenFOAM 43 May 31, 2013 10:10
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? snailstb ANSYS Meshing & Geometry 3 March 15, 2010 20:26
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
Create new material: Natural gas Van FLUENT 0 August 18, 2005 04:55
