September 12, 2007, 07:25 |
How to convert cells to polyhedral
hi,
I'm facing a problem in converting a small region of cells into polyhedral. My grid size is about 13 million with some skewed elements and has taken sometime for setting up the case, the mesh was initially adapted to correct some skewness. Now if i try to convert it to polyhedral I get an error message that the there are Hanging nodes. Is there anyway to tweak this problem in Fluent. Thanks in advance Sridhar |
September 12, 2007, 07:43 |
Re: How to convert cells to polyhedral
I dont think polyhedralisation is allowed on a mesh with existing hanging elements. Polyhedralise first and then adapt.
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
