Help to mesh in Gambit please
Old   September 25, 2007, 12:53
Default Help to mesh in Gambit please
Nicolás
Hi, Somebody could help me please,
I can not mesh a curved pipe. I make a square in the centre of the face, than I project this face to the other face and I mesh first a face with Cuad elements and Map type, than I mesh the total volume with Map Type and Hex elements . This step work well for lineal pipe, but not in curved pipe..I have problem whit the curves, because the points dont adapt themself to the edge of my pipe, they follow other line.. Maybe I must use other technique, anybody could know how can I mesh it ?
thanks very much.
Old   September 25, 2007, 13:39
Default Re: Help to mesh in Gambit please
Vinod Dhiman
Hi
The best way to mesh a volume is cooper. The only limitation cooper scheme has it that the face on which it is being projected should not have any face in between it, i.e., a face of smaller size within the face. Else, it doesn't matter whether the volume is curved or straight, cooper will work. Just mesh one face of pipe, use map if possible else pave, then use Hex and cooper scheme to mesh the volume. Source faces will include all faces except the curved face, i.e., the curved surface of pipe.
Old   September 25, 2007, 14:29
Nicolás
Hi Vinod,
Thanks for your help!
I have made the mesh with the cooper tool, but this way need a lot CPU time, approx 3,5 hours (maybe my computer is old). My pipe is 2,34 m long and a radio of 0.002 m. You say that I mesh one face, but I can not make subfaces in the original face? but how could I make a square face within a circular face? because this form is a better form to mesh circle, or not?
Regards,
Nicolás
Old   September 25, 2007, 22:27
AAA
Hi
Don't leave it to Gambit to choose the interval size along the span of the pipe. The used interval size might be too small and that's why you are using large CPU. You must control the node number on the span of the pipe. After meshing one face, and before performing the Cooper scheme, go ahead and mesh the span of the pipe (Not the entire face) with large enough intervals. Now the Cooper scheme will follow your interval size.
I hopr this helps!
AAA
Old   September 26, 2007, 09:39
Nicolás
Hi AAA and Vinod, thanks for your interest!
AAA, this is exactly that I have made, I choose the interval size along the span of the pipe, but always the CPU time is very long.
I mesh one face with 145 and than the volume with cooper tool, with 1000 points in each edge along the span of the pipe..so I can obtain 145000 cells in total.
the dimension of the pipe is 2,34 meters long and 0,002 mm radio.
Regards,
Nicolás
Old   September 26, 2007, 12:56
AAA
Hi
145000 cells is too much for a 234 cm pipe of 2 mm radius. Are you trying to resolve the properties of the wall?
What happens when you mesh one face with less cells (w/ Cooper)? What happens when you mesh the entire domain with tri-elements (w/o Cooper)?
Regards
AAA
Old   September 26, 2007, 14:07
nicolas
Hi, No, I don´t try to resolve the properties of the wall, I want to analyse what happens in each 1 mm through the pipe, but in the contain of the pipe. (milk) When I mesh how you told me, Fluent recognise a volume negative (WARNING: non-positive volumes exist)..
(When I import the geometry in Gambit (from Rhinoceros), I think that the figure is a little bit strange, because I obtain a geometry with corners instead curved)
Regards,
Nicolás
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Successive Mesh in Gambit ashish FLUENT 0 April 28, 2006 00:42
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
