Home > Forums > FLUENT
FLUENT 6.3.26 Parallel Job
Old   September 10, 2007, 18:01
Default FLUENT 6.3.26 Parallel Job
Lourival
Hy every one I'm using FLUENT 6.3.26 on parallel computations and one interesting thing is happening.
When I load it on a CPU dual core I can see that one of the CPU is full and the other is empty. The same happens when I load it on two different CPUs.
On the Windows Task Manager I can see a process called fl_mpi6326.exe with 50% of CPU (dual core). As you can see I'm using the MPICH2 as the MPI.
Does some one know what is happening? And Why it is happening??
Best regards
Lourival
Old   September 10, 2007, 18:34
Default Re: FLUENT 6.3.26 Parallel Job
Joe
Set up your hosts file correctly.
Old   September 10, 2007, 21:33
Nantaratn Kananai
If you have 2 computers and first one has 2 cores. The host file should be
computer1 computer1 computer2
Then, fluent will run on computer1 with 2 cores.
: ) nantaratn@yahoo.com
Old   September 11, 2007, 06:55
Lourival
The host file is set up OK: computer1 computer1 computer2
Maybe I wasn't clear, the process fl_mpi6326.exe is running with no Calculus. I only read the case and file and the process is already running.
Hugs
Lourival
Old   September 11, 2007, 22:15
Nantaratn Kananai
if you use fluent journal, in the end of your journal should have a command to exit FLUENT. Then, the fl_mpi6326.exe will closed automatically.
(ti-menu-load-string (format #f "exit " ))
cheers, Nant.
Old   September 12, 2007, 10:18
Lourival
Dear Nant,
Thanks for your advanced advice.
Let me describe in some more details what is happening:
When I run on CMD the following command:
fluent 3d
There is a processes whit a image name fl6326s.exe whit no CPU usage
Probably this is the SERIAL solver.
A different thing happens when I run:
fluent 3d -t2
There is four new process:
fl_mpi6326.exe fl_mpi6326.exe fl6326.exe cx373.exe
Probably the fl_mpi6326.exe is the processes that is running on each CPU and the fl6326.exe is the HOST. I don't guess what is the meaning of cx373.exe, but this is not the question.
The question here is: Why one of the fl_mpi6326.exe is running full? CPU = 50. Note that I didn't load any case. I just run the command, fluent 3d -t2, on the CMD.
Best regards
Lourival
Old   September 13, 2007, 05:25
jack
i actually face same things, when i run all the processor of my machine in parallel, before i open any cases , all my CPU are in full load.
Old   September 13, 2007, 08:23
mvee
hi i have just started using parallel processing. i thought that that is during only start up procedure. during iterate you will not find this problem. that is one thing and another that have u tried with load balancing?.
Thread Tools
Trackbacks are On
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 11 March 10, 2010 16:13
RE: Parallel job in Vista-32 Kevin FLUENT 1 July 11, 2008 12:22
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 10:52
