Too many VOF sub-timesteps problem
hi,all
i am simulationg a free surface movement using VOF.when the mass flux of mass inlet is defined and time step is 0.002s,my computer tell me: "Updating solution at time level N... Error: Too many (3760548593) VOF sub-timesteps. The velocity field is probably diverging. Please check the solution, and reduce the time-step if necessary. Error Object: ()" when time-step is 0.2s,error is following: "Updating solution at time level N... Error: Too many (274569734) VOF sub-timesteps. The velocity field is probably diverging. Please check the solution, and reduce the time-step if necessary. Error Object: ()". why? how to do it? |
Re: Too many VOF sub-timesteps problem
I think u shud try with timp step of .000002 and then gradually reduce n keep no of iteration s per time step at first to 50 and also remove any convergence criteria.and then gardually decrease time step size and then max no of iteratiuon per time step to 20 and then enable convergence criteria
i try it using 0.00002,but my computer rell me:"error:floating point error:invalid number. why? wanghongbjut@yahoo.com.cn
| All times are GMT -4. The time now is 04:56. |
