-   -   Inflow without outflow! (http://www.cfd-online.com/Forums/fluent/46029-inflow-without-outflow.html)
ANASTASIOS GEORGOULAS September 14, 2007 04:54
Hi to all,
I am running a simulation in a 3d geometry. I have 2 phases water liquid is my primary phase and water with suspended material is my secondary phase.
i have a closed tank (no outflow boundary condition) with wall boundary conditions all around and i use an inflow boundary condition i a small opening in one of the walls.
The funny think is that i get very good results and all the equation converge normally, but i am not using any outflow!
My question is if that is correct cause i suppose that the continuity equation should not converge since i am not using any outflow.
i would appreciate any help!
kuba September 14, 2007 05:51
Re: Inflow without outflow!
You can try VOF scheme.
ANASTASIOS GEORGOULAS September 14, 2007 07:43
Thanks for the reply!
Anastasios Georgoulas September 15, 2007 03:58
Dear Kuba,
Since you are sugesting the VOF model do you know if i can use the open channel formulatrion using 3 phases?
Air primary phase (above the free surface) Water-liquid secondary phase1(below the free surface) Water with sand secondary phase2(below the free surface)
Thanks in advance!
