Urgent Gambit help
Old   September 15, 2007, 15:35
Default Urgent Gambit help
rosol
Hi Please who can help me to meshing the trapezoidal 3D channel becaouse I canot meshing it .Note that the dimensions is in micron and the problem in meshing the volume since the edges and faces were meshed properly.
I will appreciat for any help
Old   September 15, 2007, 20:01
Default Re: Urgent Gambit help
AAA
Hi
The micron dimensions shouldn't be a problem. Have you tried meshing the whole domain w/o starting with meshed faces?
I assume that since this is a channel, there would be two parallel faces for inlet and outlet. If so, use the "Cooper" scheme for this. Another way would be to start by meshing one of those faces only, then use the "size function" to mesh the whole domain.
Please let me know if this helps.
Regards
Old   September 17, 2007, 10:38
rosol
Dear AAA ,sat,
I would like to inform you that .This way were not goin good with me and the volumes does nod meshed .Can you expalain the way in more details .Not that my geometry consists of three volumes two trapezoidal channels and one rectangular channel one obove the other which represent a heat exchanger :the first trapezoidal channel then rectangular wall then second trapezoidal channel.
Please I need some of your time to help me with this probles
Thank you very much for your interst
Old   September 17, 2007, 10:57
rosol
Dear AAA ,sat,
Old   September 17, 2007, 11:02
rosol
Dear AAA ,sat,
I would like to inform you that .This way were not going good with me and the volumes does nod meshed .Can you explain the way in more details .Not that my geometry consists of three volumes two trapezoidal channels and one rectangular channel one above the other which represent a heat exchanger :the first trapezoidal channel then rectangular wall then second trapezoidal channel.
Please I need some of your time to help me with this problems
Thank you very much for your interest
Old   September 17, 2007, 20:52
AAA
Hi Rosol
If you have three volumes, you should be able to mesh them individually. If you can post your domain, I'd be happy to help.
Regards
Old   September 18, 2007, 10:54
rosol
Dear AAA, Thank you for your help Can you please send me your email to send you more details about my work.
I will appreciate your help
Old   September 19, 2007, 14:19
rosol
my email is rosolm2000@yahoo.com
if you want to help me please send an email to this email address and I will send you any usful information
with thanks
Old   September 19, 2007, 14:39
rosol
with thanks
[GAMBIT] URGENT!!! "Import from GAMBIT to ANSYS-12.1 (Design Modeler/Geometry)" MDinc ANSYS Meshing & Geometry 13 September 13, 2012 09:26
URGENT!!! "Import from GAMBIT to ANSYS-12.1 (Design Modeler/Geometry)" MDinc FLUENT 1 November 24, 2010 01:59
Frustrated Gambit Newbie:Please reply, Urgent Rajil Saraswat FLUENT 2 July 18, 2003 04:56
GAMBIT, LABEL ( URGENT ) Ahmed FLUENT 1 May 5, 2003 14:59
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
