Time Parallel run
I want to time my parallel CFD network using a typical work case which will run for 100 iterations, from 1 to many computers. Is there a way of doing that in a systematic way so I don't need to time the run myself with a stopwatch?
Re: Time Parallel run
If youre on unix/linux use the time command.
I'm running windows. Any suggestions there?
A less accurate way could be to have it write a very small file at the start and end of your run; maybe use execute command.
For FLUENT6.3 and newer you may use the following command to get the accurate timers both wall and CPU:
(proc-stats) |
I do run 6.3 but I am not able to find the command.
