October 6, 2007, 02:34 |
Help with Boundary Conditions
I have problem in assigning BC for propeller simulation. I use fan BC to represent the propeller. I draw a tube isolating the fan surface. The BC is pressure inlet --> fan --> pressure outlet and the skin of the tube is symmetry. Am I using the right BC? I have Thrust vs RPM data from experiment. I can calculate the induced velocity and pressure jump using momentum theory. I set the P operating as 1 atm. I notice that the P total in inlet should be around 1 atm and at inlet the P static is 1 atm, whereas the P total is unknown. What should I put in gauge pressure column at Pressure inlet and outlet BC? Right now, I keep it 0. It gives me wrong physical characteristics. the velocity is almost uniform everywhere, while the Velocity at oulet (V advance is 0 for hover condition) should be 2x the velocity at the fan surface. I think I have made a mistake.... |
October 6, 2007, 08:09 |
Re: Help with Boundary Conditions
1.formula to calculate P total in respective to mach number 2.operating number at inlet set to 0 when not big pressure drop 3.specify the BC at Propell in cell zone Fluid?(i am also not sure about that,cos so far i dealt not too much with propell)
October 6, 2007, 09:01 |
Hi jesse,
Thank for your answer. Isn't that total pressure as M function is for compressible flow? I'm simulating incompressible flow since the velocity is very low. Have you tried similar model before? maybe you can share your experience. |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
