Significance of COURANT nUMBER
Old   September 9, 2007, 18:13
Default Significance of COURANT nUMBER
sridhar
Hi everyone, I am doing supersonic flow study in a combustor.I want to know how important is the effect of Courant number on the solution ,convergence etc. I am presently using Courant number of 0.5. How far can I change it from my present value to get better results.
Regards sridhar
Old   September 10, 2007, 12:56
Default Re: Significance of COURANT nUMBER
Joe
A CN of less than 1 is always satisfactory for an implicit solver. Practically a RMS CN <= 1 and MAX CN <= 5-10 is usually satisfactory for adaquate accuracy for an implicit solver. You can go bigger but you must then show solution insensitivity to a CN > 1.
Old   September 12, 2007, 11:47
sridhar
thanks for the rply .. just help me out with another small doubt of mine ..mine is an injection problem and the main flow is supersonic with sonic injection .I would like to know . should I start with UNSTEADY solution or start with STEDY SOLN and then switch to unsteady solution.. Please suggest ..thanks
Old   September 26, 2007, 16:14
Kaiser Matin
Start with a steady solution and then do the unsteady soultion.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
COURANT NUMBER Ferreira Main CFD Forum 23 February 26, 2006 18:10
