What's wrong with my UDF? It worked in the past. |
September 26, 2007, 08:40 |
I've got a udf which my friend passed me. It's used to simulate a body moving up/down in a fluid. I've used it before and it worked. However, now when I tried to use it, I've problems compiling. My sch now uses fluent 6.3 but I wonder if that's the problem. My UDF is #include "udf.h" /* this function defines velocity of center of gravity for pure plunging motion*/ /* Plunging motion equation is z(t)=h*sin(2*pi*f*t) */ DEFINE_CG_MOTION(plungnew, dt, vel, omega, time, dtime) { thread *t; face_t *f; /*reset velocities */ NV_S(vel,=,0.0); NV_S(omega,=,0.0); if (!Data_Valid_P()) return; /* Get the thread pointer for which this motion is defined */ /* t=DT_THREAD(dt); */ /* vel[1] is the vertical plunging velocity */ /* These velocity below is for h=0.4c and f=0.993Hz */ vel[1] = 0.1910088333*cos(0.9550441667*time); } The error message is: # building library in lnia64/2ddp make[1]: Entering directory `/home/enduser/g0306332/fluent_intro/libudf/lnia64/2ddp' make[1]: *** Warning: File `makefile' has modification time in the future (2007-09-26 20:39:03 > 2007-09-26 20:37:44.628237) # Generating udf_names.c because of makefile plungnew.c make[2]: Entering directory `/home/enduser/g0306332/fluent_intro/libudf/lnia64/2ddp' make[2]: *** Warning: File `makefile' has modification time in the future (2007-09-26 20:39:03 > 2007-09-26 20:37:45.151532) make libudf.so "CFLAGS=-fpic -shared -ansi -Wall -O -DPTR_RESTRICT= " "LDFLAGS=-shared -lm" "LD=cc" make[3]: Entering directory `/home/enduser/g0306332/fluent_intro/libudf/lnia64/2ddp' make[3]: *** Warning: File `makefile' has modification time in the future (2007-09-26 20:39:03 > 2007-09-26 20:37:45.324747) # Compiling udf_names.o because of udf_names.c cc -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/app1/common/Fluent.Inc/fluent6.3.26/`expr \`pwd\` : '.*/\(.*\)/[23].*'`/`basename \`pwd\`` -I/app1/common/Fluent.Inc/fluent6.3.26/src -I/app1/common/Fluent.Inc/fluent6.3.26/cortex/src -I/app1/common/Fluent.Inc/fluent6.3.26/client/src -I/app1/common/Fluent.Inc/fluent6.3.26/tgrid/src -I/app1/common/Fluent.Inc/fluent6.3.26/multiport/src -I. -c udf_names.c # Compiling plungnew.o because of plungnew.c cc -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/app1/common/Fluent.Inc/fluent6.3.26/`expr \`pwd\` : '.*/\(.*\)/[23].*'`/`basename \`pwd\`` -I/app1/common/Fluent.Inc/fluent6.3.26/src -I/app1/common/Fluent.Inc/fluent6.3.26/cortex/src -I/app1/common/Fluent.Inc/fluent6.3.26/client/src -I/app1/common/Fluent.Inc/fluent6.3.26/tgrid/src -I/app1/common/Fluent.Inc/fluent6.3.26/multiport/src -I. -c plungnew.c plungnew.c: In function `plungnew': plungnew.c:6: `thread' undeclared (first use in this function) plungnew.c:6: (Each undeclared identifier is reported only once plungnew.c:6: for each function it appears in.) plungnew.c:6: `t' undeclared (first use in this function) plungnew.c:7: warning: unused variable `f' make[3]: *** [plungnew.o] Error 1 make[3]: Target `libudf.so' not remade because of errors. make[3]: warning: Clock skew detected. Your build may be incomplete. Can anyone help? Thanks |
September 26, 2007, 09:54 |
Re: What's wrong with my UDF? It worked in the pas
I've rewritten the udf for easy viewing:
#include "udf.h" /* this function defines velocity of center of gravity for pure plunging motion*/ /* Plunging motion equation is z(t)=h*sin(2*pi*f*t) */ DEFINE_CG_MOTION(plung185, dt, vel, omega, time, dtime) { thread *t; face_t *f; /*reset velocities */ NV_S(vel,=,0.0); NV_S(omega,=,0.0); if (!Data_Valid_P()) return; /* Get the thread pointer for which this motion is defined */ /* t=DT_THREAD(dt); */ /* vel[1] is the vertical plunging velocity */ /* These velocity below is for h=0.4c and f=0.993Hz */ vel[1] = 0.1910088333*cos(0.9550441667*time); } |
September 26, 2007, 18:22 |
Try "Thread *t" instead of "thread *t". That is certainly a problem.
Jason D. |
September 26, 2007, 20:09 |
Ya it worked! tks.
I wonder why it didn't worked b4... |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
DEFINE_DPM_OUTPUT macro UDF HELP | Puneet | FLUENT | 3 | November 28, 2003 10:55 |
DEFINE_ON_DEMAND UDF: How to declare A[ND_ND], etc | jx | FLUENT | 1 | November 6, 2003 17:23 |
DEFINE_GEOM UDF Problems | Pat | FLUENT | 0 | August 14, 2003 13:16 |
