Home > Forums > FLUENT
FFT problem
Old   October 1, 2007, 02:49
Default FFT problem
rav_aero
hey can anybdy tell me how to do FFT(fast fourier transform). my data consists of pressure and time. now i need to do FFT to find the dominant frequency. in fluent its written that i need to give the input signal file. but how do i generate the signal file? is there any other way by which i can do it?
thank u.
Old   October 1, 2007, 12:14
Default Re: FFT problem
Mat W
this has been covered in this forum several times before, do a search. in short, you need to create an output file which has two columns - one for time and one for the time dependent variable. This can easily be done by going into Solve>Monitor>surface and selecting the time dependent variable you want to monitor (in your case some measurement of pressure). The file will update after each time step. Once you are happy you have enough time steps to represent the time dependent characteristics, load the file into the FFT panel.
Old   October 2, 2007, 23:49
rav_aero
Thank u very much Mat..
Thread Tools
Trackbacks are On
engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 3 February 23, 2013 21:41
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
