Home > Forums > FLUENT
HELP DIVERGENCE NITA!!
Old   October 1, 2007, 10:59
Default HELP DIVERGENCE NITA!!
Hadi
Hi to all,
I am running, LES channel flow, i ran K-epsilon by fixing a constant flow rate, and then i applied the perturbation,when running LES, after few iterations the bulk velocity will increase from 1m/s to 30 m/s ,then it changes its direction,and the simulation blows!! By looking to the residuals the contiuity is always increasing.
I ran the same simulation using another code and i didn't face any problem, so i think the mesh is ok, and the courant number is less then 0.25! can you please tell em what might be wrong.
Any help will be appreciated!
Cheers Hadi
Old   October 2, 2007, 05:18
Default Re: HELP DIVERGENCE NITA!!
Jim
Do you encounter reversed flow problem? And does the problem come from the near-wall?
Old   October 2, 2007, 06:23
Hadi
Well maybe i found the solution, i am not sure though. When you specify a constant mass flow rate, iterations are needed to adjust the flow at each time-step, NITA is a non iterative scheme, so it only works by fixing a constant pressure gradient.
i encountered a reversed flow, but i think it is a numerical error.
I am running now the simulation without NITA, and till now it is working well.
What about your simulation?
Thread Tools
Trackbacks are On
UDF divergence of a vector cris FLUENT 3 September 4, 2014 18:06
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
LES NITA giving divergence problems anindya FLUENT 0 June 20, 2005 07:23
divergence in MAC Method Maciej Matyka Main CFD Forum 2 December 19, 2000 11:43
