-   -   Can't open Case and DATA File (http://www.cfd-online.com/Forums/fluent/46251-cant-open-case-data-file.html)
chern October 8, 2007 01:08
I have big problem ,After Run Program it's convergence already, write Case and Data After that can't Open file.
Jones October 8, 2007 05:51
Re: Can't open Case and DATA File
Please check the model
the big problem is : if your model is 3D but u open it by 2D in fluent or opposite.
I hope help
chern October 9, 2007 05:05
Thanks you for advice : my problem is (Read case and data -define- boundary condition-solve-control-solution)I want to save this setting and I done (File-Write-case and data) After that when open this file it's show
: Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION). Error Object: () Hit return to exit.
Jones October 11, 2007 10:43
It could be you dont save same name of data file and cas file. Fluent refer to same name for dat and cas file. Next you have to save the cas and dat file in same name. If not, when you try to open the resulat by -->file -->open cas and data--> will error.
Sources are many, because your case already convergen, i elieve you made different case and dat file name.
Please correct me if i wrong
Best Regards
chern October 16, 2007 05:58
Thank you very much Jones for advidce, For my problem (Read-case and data - Set BC - Iteration-Sulution convergence- write case and data(Same name and write binary files was mark) - after that I exit from FLUENT and next time i can't read case and data form this file ... I want to know the meaning of (write binary files) may be it's key word of this problem You think so ?
My English isn't good. Chern
Aris Nikolopoulos October 16, 2007 09:07
Binary is just a codex. You will have problems only when trying to move from Windows to Linux. Try to read, only the case file and then the data file.
Ekkachai April 19, 2016 11:08
can not read case and data
Originally Posted by chern
;146241
I have a same problem what do you solve it.
