Gambit error on linux: Unable to open file ... |
October 4, 2007, 06:44 |
We just installed the latest gambit version (2.4.6) on a linux operating system. Everything seems to work fine (i can make+save and open .dbs files) But it fails to open an older .dbs files that's made with a previous version of gambit. It gives the following error and then loads the default_id.dbs: ERROR: Unable to open file "RxMRF.dbs", for reading and writing I'm not sure what the problem is, so any idea's are welcome. My guess would be that there is a security issue and i'm not allowed to write the file? Is there a possibility to yust open the .dbs file without the writing option? Thanx for your help, Wim |
October 10, 2007, 11:06 |
Re: Gambit error on linux: Unable to open file ...
Are you sure that there is enought space in disk? It is strange, perhaps you haven't write permissions for this file. Try to open gambit as usual and then run the journal file associated to this gambit session (named RxMRF.jou) Best regards |
Display Modes | |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 15:49 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
