October 10, 2007, 15:30 |
Making arc on circle surface
Hi
Can any one help to plot or making an arc on the surface of sylindrical volume thanks |
October 11, 2007, 05:56 |
Re: Making arc on circle surface
don't be too accurate in your questions....
October 11, 2007, 13:55 |
I need to creat an arc in some place in a sylinder like the line plotting by surface -line/rake-line tool to be compute some variables along this arc or curved line
thank you |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Possible bug in blockMesh | benru | OpenFOAM Bugs | 16 | August 17, 2013 19:54 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
