wrong velocity & temp at initialization
I've got an Issue concerning total gauge pressure. I know this topic has been discussed numerous times, but so far I have not come across a thread, that would answer my particular question.
I work on simulating a free-flow at M=0.8, p_stat=26436.2426 Pa, and T=223.15K. I calculated the total pressure to be p_tot=40297.8223 Pa and the total temperature to be T_tot=251.7132. I set the Operating Pressure to "0", input the p_tot for the Pressure Inlet at "Total Gauge Pressure", p_stat at Initial Gauge Pressure and T_tot at Total Temperature. So far so good. When I want to initialize the calculation and set "compute from" to my Pressure Inlet, Fluent puts out a Gauge Pressure of 26436.18 Pa (not too far off), a velocity of 222.9477 m/s (at T=223.15 and 0.8M it should have been 239.704) and a temperature of 165.1291 (now, where did this come from). Via try and fail I found out that when I input a Total temperature of 323.2376 K and a Total Gauge Pressure of 38293.5 Pa I get the desired Initial Values. These Inputs don't mirror the real conditions though, so I wonder what I could be missing here. Regards, Leo |
Re: wrong velocity & temp at initialization
By the way - this problem occurs only, when in the material's setup cp is turned to kinetic energy.
