October 15, 2007, 11:46 |
Multiphase flow
Hi
I am running a simple multiphase jet case with primary phase as air and secondary phase as water.The location of nozzle is at the left corner and the rest of the bcs are pressure outlets. After convergence, the results for volume fraction are not showing any dispersion. I tried a case reducing the prandtl dispersion coefficient.The result is the same. Any suggestion is appreciated. Thanks Sri |
October 15, 2007, 16:48 |
Re: Multiphase flow
I am giving more description about my case. When I try to inject 70percent water and 30%air into the domain,after few iterations the domain shows the mixture everywhere.I tried running this case with both steady and unsteady solver.I am using an eulerian multi phase model.
Your suggestion is highly appreciated. Thanks Sri |
Display Modes | |
Multiphase flow! | Amer | FLUENT | 2 | May 16, 2012 15:57 |
Multiphase flow information | amir | FLUENT | 2 | May 25, 2007 06:01 |
Realizable k-epsilon eqns for multiphase flow | Rana | FLUENT | 0 | December 8, 2006 13:46 |
Multiphase Flow | mbga8ejf | CFX | 0 | July 10, 2003 10:26 |
multiphase flow | Shane Gillis | FLUENT | 10 | August 28, 2000 19:12 |
