How can we extract the impact angle from a trackin |
October 15, 2007, 18:20 |
hi there: nice to be here. I want to know how to extract the impact angle form a result of DPM tracking.are there any direct or indirect way to extract the impact angle from a solution. thanks
October 17, 2007, 10:34 |
Re: How can we extract the impact angle from a tra
I kmow an indirect way:
need to have phase interaction on turn the erosion model on in the wall BC you see the erosion mode which is a function of the impact angle. set the paramters such that the erosion rate is equal to angle value. There may be easier ways. |
How to output particle impingement angle (impact angle) ? | Rez | CFX | 1 | May 22, 2015 11:54 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
How to pass impact angle values in Erosion UDF | sravan451 | FLUENT | 1 | September 16, 2010 23:59 |
Impact velocity and angle from DPM model in Fluent | eng775 | FLUENT | 0 | September 4, 2009 14:34 |
Plotting particle wall impact angle (Lagrangian pt | Bart Prast | CFX | 0 | January 26, 2009 04:23 |
