modelling airfoil flow near stall
Old   October 17, 2007, 05:16
Default modelling airfoil flow near stall
nico
I am looking at a 2D case for now. I need to model flow from 0deg up to near stall.
Everything is fine until i get more and more trailing edge separation.
Currently i expect to have around 20% of separation on the suction side.
I am using the SST model (and might try the RSM).
My current process is to run in steady mode using an upwind interpolation on the momentum terms, when it's steady (separation is obvisouly not well predicted), I switch back to second order and solve in unsteady.
What typical value of time step should I use (Re=10000) ? Are there any papers around dealing with that?
energising the flow over an airfoil using synthetic jets aerojeeva21 FLUENT 5 March 4, 2011 07:47
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
ask help on valve flow simulation(3D modelling) Anna FLUENT 0 July 18, 2003 17:39
Compressible Flow Modelling? yeo FLUENT 4 March 7, 2003 07:08
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
