Coal Particle Tracking
Hello I'm currently trying to trace out each coal particle in Fluent. I noticed when I use DPM Particle Tracking, I'll receive a data file that begins with Time column,X-posiiton,Y..Z,... Temperature...Mass...Color by and so on. I looked at the file and noticed that the time goes from 0-7..seconds or so, the begin at 0 again and continues on down the column. Does that mean as soon as the time reset to zero on the data sheet, Fluent is displaying another particle?
Is there a way where I can just track 1 PARTICLE ONLY and look at its time, temp...distribution? Thank you |
Re: Coal Particle Tracking
Have you several injection points? Because I think that in the coordinates of zero-time row, you should find the injection position and diameter value, so you can understand if it is another particle from the previous one... fluid
Hello Yes, I have several different injection points. However, when I extract the particle, I extract from only 1 injection point. Within this injections 3000 particles were recorded. Is it a correct assumption that every times the "time" column reset to zero, you can say that it's now tracking a new particle?
Thanks |
sorry, I'm not sure because the manual doesn't specify it, but i suppose so....
Yes when the time resets to zero it does mean that it is a new particle. Unfortunately with Fluent there is no possibility of tracking a single particle if you have multiple particle injections. I would second fluid's suggestion of looking at the particle dia and position to confirm that the tracking has changed from one particle to another.
| All times are GMT -4. The time now is 13:52. |
