October 12, 2007, 01:31 |
y+ application
hello for automotive application how and at what stage y+ is applied .anybody please thanks
October 22, 2007, 06:46 |
Re: y+ application
which automotive application you mean to say? suppose if you are calculating drag coefficient on your vehicle using relaizable k epsilon model, then your y+ shall be somewhere between 30 to 100. so if you intend to maintain the Y+ you can adjust the first prism height at the boundary accordingly.
October 22, 2007, 12:17 |
Re: y+ application
o.k fine thank you for the information. Actually what i want to know is whether y+ is applied before volume meshing or after.Normal steps followed in solving aerodynamics problem are (car geometry+virtual wind tunnel+geometry clean up+surface mesh+volume mesh) So in this process when to apply y+. It would be very glad if you could answer my second querry also. Fluent gives skin friction coefficient.Whether this should be treated as total drag or else how to work out total drag (Pressure drag+skin friction drag) or is it a pressure drag as car is more or less a bluff body and has a pressure drag as measure component. thank you again.
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Others library application for OpenFoam 1.5 in Windows | lcnmy | OpenFOAM Installation | 2 | July 21, 2010 20:54 |
Installation of OpenFOAM15dev | antonio_ing | OpenFOAM Installation | 34 | December 18, 2009 10:06 |
Application of Lid Driven Cavity | Adrian | FLUENT | 0 | October 23, 2008 22:18 |
MPI Application in HPC | wendy | Siemens | 0 | May 19, 2005 01:50 |
