October 19, 2007, 13:42 |
Revolving a face in gambit - Help needed!
Is it possible to create a volume by revolving a circle through 360 degrees, keeping one side of the circle a uniform distance from the origin (axis of rotation), whilst the circle diameter increases at a set rate per degree?
I.e. A circle has a radius of 5ft, and is 2ft away from the origin at its nearest point. It is revolved 360 degrees around the origin. This circle radius increases at a rate of 1ft/degree rotation. The end result is a revolved volume with on end having a circle with a 365ft radius, which is 2ft away from the origin at its closest point. I am trying to model a centrifugal pump volute, but Im having trouble getting the more intricate geometries around the tongue to mesh. |
October 19, 2007, 14:45 |
Re: Revolving a face in gambit - Help needed!
I think you may need to use an extrude along path.
I would make a path of the center line (a spiral), an then extrude the 5' rad circle along it with a draft angle of what ever is the right angle to get 1ft/1deg. |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Help needed with Cornell's Gambit airfoil tutorial | Arti | ANSYS Meshing & Geometry | 3 | May 30, 2009 03:40 |
gambit coincident face error | philip | FLUENT | 1 | July 18, 2005 15:12 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Help Needed: Gambit Problem (2-D) | Huawei | FLUENT | 3 | April 13, 2003 20:45 |
