Axis of rotation for centrifugal compressor
Old   October 19, 2007, 09:09
Default Axis of rotation for centrifugal compressor
Mattia
Dear all,
I'm Mattia and I'm a PhD student at the Delft University of Technology (The Netherlands).
At the moment, I am analysing a radial compressor by means of CFD: I am using GAMBIT 2.3.16 for mesh generation and FLUENT 6.3.26 for simulations.
At first, I am using a single rotating frame, which means that everything is rotating (both inlet and outlet basically, because that compressor does not have any diffuser).
Now, my big concern/doubt is the axis of rotation. In the manual is it said that "For 3D problems - and this is my case -, the axis of rotation is the vector from the Rotation-Axis Origin in the direction of the vector given by your Rotation-Axis Direction inputs". Thus, if I select, for the rotation axis direction x=1 y=0 z=0, it means that the direction of rotation is around x-axis.
Well, if the x-axis is going into the screen (in order to talk easily), this means that the rotation should be clockwise, isn't it?
Anyway, how can I be 100% about the direction of rotation in those terms?
I hope I could express my idea.
Thank you. Kind regards, Mattia.
Old   October 19, 2007, 14:56
Default Re: Axis of rotation for centrifugal compressor
Glenn
Yes, you expressed your thoughts and ideas very clearly. You can check your solution by plotting relative and absolute velocity vectors. The relative vector plot is ratating with the control volume... the absolute vectors should illustrate the rotation of your control volume, with teh relative vectors superimposed. The difference in magnitudes should be the (omega)*(radius) magnitude.
Old   October 22, 2007, 08:43
Mattia
Thank you.
But what do you exactly mean with ABSOLUTE VELOCITY VECTORS?
I cannot find that quantity in the VECTORS panel.
Regards, Mattia.
Old   October 22, 2007, 09:03
Glenn
From the main window --> Display Vectors --> Vectors of: (2 choices available... a) "velocity" = absolute velocity, or b) "relative velocity" = velocity relative to the control volume specification) Hope this helps...
Old   October 22, 2007, 11:05
Mattia
Yes, it does.
Btw, only then I realized that "velocity magnitude" is the absolute one, because the "relative velocity" is explicitly expressed.
thank you.
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
Rotation Axis in Fluent arapha FLUENT 3 November 8, 2016 21:44
Relief Plots in CFX Michael CFX 15 June 30, 2006 08:01
Axis of rotation Dunga CFX 4 May 11, 2003 10:44
rotation axis? Max FLUENT 5 December 5, 2000 04:53
