October 25, 2007, 03:10 |
some questions for supersonic channel nozzle
Hi, everyone,
I am doing some simulation of supersonic nozzle. In my case, the nozzle has a rectangular throat of 5x30mm and a rectangular throat of 5x500mm. Is it possible to get a non-seperative supersonic flow inside the whole nozzle?? I know that the boundary layer will significantly effect the flow field in the nozzle, but I don't know how to consider it when I build the model and simulate. Can anyone give me some advices of how to consider this kind of problems? P.S, I have some experience of the simulation of circular supersonic nozzle. |
November 2, 2007, 02:27 |
Re: some questions for supersonic channel nozzle
You can avoid separation by optimising the nozzle outer contour.
November 4, 2007, 21:18 |
Thank you for your kind reply.
My question is to find the Non-seperation dimensions. I want to get the nozzle exit width as wide as possible, for example, 500mm. At the same time, I want to decrease the throat size as possible for saving the gas used. The problem is to find in which condition the seperation will be occures. Then I can decide the throat size and exit size. Any recommandation will be welcome. |
Questions a Laval Nozzle | lvxiang | OpenFOAM Running, Solving & CFD | 9 | April 16, 2013 08:23 |
gas flow out of a C-D channel | ljp | FLUENT | 0 | March 7, 2011 14:32 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
Regenerative cooling nozzle. | Brian | Fidelity CFD | 3 | September 1, 2005 08:53 |
Regenerative cooling nozzle. | Brian | Main CFD Forum | 0 | November 10, 2003 01:11 |
