October 28, 2007, 11:21 |
K-E values not converging
Hi Guys,
I am running a simulation using the standard K-E model. The problem is that whilst monitoring residuals I have noticed that all the variables e.g. x, y ,z velocity etc are converging but the kappa and epsilon values are extremely unstable and diverging. Can anyone help with this please? Thanks. |
October 28, 2007, 23:33 |
Re: K-E values not converging
try to varie the energy between 0.95-1.0 in controls-solution-under relaxation factor
November 2, 2007, 03:42 |
Check you grid resolution before altering the model coefficients.
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 10:38 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 11:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
