UDF problem
i have to define a UDF function for the displacement of diaphragm deflection of a chamber. the chamber is filled of liquid. Due to movement of diaphragm the liquid flows out from the chamber. the velocity of the diaphragm is given in the following UDF function.
#include "udf.h" static float V_Prev=0.0; DEFINE_CG_MOTION(unsteady_velocity, dt,vel, omega,time,dtime) { thread *t; face_t f; float NV_VEC(A); float velocity; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P()); return; t=DT_THREAD(dt); velocity = (0.0000004*2.*3.1415926*300 cos (2.*3.1415926*time*300.)); begin_f_loop(f, t) { V_Prev(A, f, t) = velicty; } end_f_loop(f, t) message ("time = %f, z_vel= %f", time, V_Prev); vel[0]=V_Prev; } i write this udf function with the help of CG motion udf given in the manual. this UDF function gives so many errors when i try to compile this function. i shall be very very thankful to any one who will help me in this regard. |
