variable initiallization
Old   November 6, 2007, 05:25
Default variable initiallization
sm
i have 2D rectangular geometry. I want to assign a constant value to a variable upto a certain height in the y-direction initially. How do i do that in Fluent? sm
Old   November 6, 2007, 11:09
Default Re: variable initiallization
max
Hi sm
use adapt-region to mark all cells below your specified y-value.
After that, assign the desired value using solve/initialize/patch
cheers
Max
Old   November 6, 2007, 23:12
sm
Thanx Max. But why is the refinement of the grid "on". I do not want to refine the grid, so i have put the refinement factor as 1. sm
Old   November 7, 2007, 03:26
max
In the Adapt/region panel do not push the Adapt button but just "mark".
Old   November 9, 2007, 04:05
sm
Thanx Max
Additional Variable tav98f CFX 3 April 28, 2011 12:33
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
