K-E values not converging
Old   October 28, 2007, 11:21
Default K-E values not converging
NK
Hi Guys,
I am running a simulation using the standard K-E model.
The problem is that whilst monitoring residuals I have noticed that all the variables e.g. x, y ,z velocity etc are converging but the kappa and epsilon values are extremely unstable and diverging.
Can anyone help with this please? Thanks.
Old   October 28, 2007, 23:33
Default Re: K-E values not converging
hari
try to varie the energy between 0.95-1.0 in controls-solution-under relaxation factor
Old   November 2, 2007, 03:42
Ahmed Yakyaki
Check you grid resolution before altering the model coefficients.
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
