November 4, 2007, 05:44 |
urgent need help with wall adhesion angle
can anyone tell me how much the value of contact angel for (water-air) flow over each other must I set at wall boundary?
cheers kb |
November 6, 2007, 01:03 |
Re: urgent need help with wall adhesion angle
Is there anybody can answer me this question I not think it too difficult? who can answer me please?
kb |
November 7, 2007, 14:28 |
HI: It depends on your surface material. The contact angle can vary a lot. It is surprisingly difficult to find a good reference with contact angle data for different surfaces. For example, on steel you might use 75deg, but on typical quartz you would use maybe 30deg. Note also that what you enter into Fluent depends on which phase you defined as the primary phase (see user guide).
Thin Wall Heat Transfer BC for rhoSimpleFoam | swahono | OpenFOAM Running, Solving & CFD | 12 | October 4, 2013 11:49 |
how to specify wall contact angle for compressibleInterFoam? | phsieh2005 | OpenFOAM Running, Solving & CFD | 4 | December 18, 2012 15:01 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
Plotting particle wall impact angle (Lagrangian pt | Bart Prast | CFX | 0 | January 26, 2009 04:23 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
