Home > Forums > FLUENT
dynamic mesh
Old   November 5, 2007, 14:14
Default dynamic mesh
Mehdi
Hi everyone, I was trying to follow the example of the fluent on the dynamic mesh (poppet valve). I came up with a error message when compiling the UDF file (valve.c). I can not compile the file. The error message is as follow: when i click on the build, i receive this message:
(system "copy C:\Fluent.Inc\fluent6.2.16\src\makefile_nt.udf libudf\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
and when i click on the load, i receive this: Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
I have to mention that all the UDF files are in the same directory that contains my case and data files.
I really appreciate, if you can help me with this problem.
Old   November 5, 2007, 17:36
Default Re: dynamic mesh
Sham
You need to start Fluent from Visual Studio C++
Old   November 5, 2007, 18:33
Mehdi
Thank you Sham. How can I start Fluent from Visual Studio C++?
Old   November 5, 2007, 19:07
Sham
You need to download the application and start Fluent from the command prompt. If you search this forum, there is a lot of discussion on teh topic.
Old   November 5, 2007, 19:17
Mehdi
thanks a lot.
Thread Tools
Trackbacks are On
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
Dynamic Mesh on Pintle type injector. herntan FLUENT 15 January 4, 2012 04:31
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 1 July 28, 2011 01:53
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
