November 26, 2007, 03:20 |
udf help
hi
is it possible to run a seperate equation using udf in each time step at every cell? thank you |
November 26, 2007, 11:05 |
Re: udf help
yes. you can do it with a UDS definition.
November 26, 2007, 22:23 |
Re: udf help
hi max
thanx for your reply.can i make it in unsteady formulation? thank you once again |
November 27, 2007, 03:07 |
Re: udf help
yes, you can find good helps in the UDF manual.
November 27, 2007, 03:35 |
Re: udf help
thank u once again
hi i need to add this term as a source (8x2y2) x and y are the grid number or position ie 1,2,3.... wat macro i can use for solve this? |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
