how can I increase Y-plus in 2D geometry
Old   November 26, 2007, 14:46
Default how can I increase Y-plus in 2D geometry
rb
Hi I am simulating 2D geometry I saw my y+ value very law can anyone guide me how can i increase it?
rb
Old   November 27, 2007, 04:42
Default Re: how can I increase Y-plus in 2D geometry
Kasper
Take a look at this to understand y+: http://www.cfd-online.com/Wiki/Dimen..._wall_distance
Y+ is the non-dimensional wall distance. The formula y+ = u(star) * y / kin_visk, says it all for you.
If you wan't to increase y+ value then make the center of you first cell further from the wall. Or change the kinematic viskosity.
The value of y+ in the first cell should be controlled in regard to what you are modelling. Take a search on y+ in forum and you will find loads of information.
BR Kasper
Old   November 27, 2007, 05:28
rb
Hi thanks for the information you sent. I saw the formula for estimating the desire grid distance but it was mentioned for flow a flow over a flat plate? is it work for the case of pipe flow and how much the value of Ref. length in this case for y+=41 & diameter=77.92 mm?
rb
Old   November 28, 2007, 02:55
Kasper
I think the diameter could be the reference length, but I'm not sure. Use the grid spacing calculator: http://geolab.larc.nasa.gov/APPS/YPlus/#TOTAL
and insert y+=41 ref.length=0.07792m and your Re no.
But why are you using y+=41?
BR Kaspeer
Old   November 30, 2007, 09:53
rb
because I need to use the non-equilibrium wall function as wall treatment so I want set y+ over 30? Do you have another suggestions?
rb
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
