How to plot pressure gradient in Fluent?
Old   November 10, 2007, 02:19
Default How to plot pressure gradient in Fluent?
jrg
Hi. I can't seem to find this option in fluent. I want to plot d(Pressure)/dx along a channel. Do I have to create user defined functions? If so how should I go about doing it?
Thank you.
Old   November 12, 2007, 04:40
Default Re: How to plot pressure gradient in Fluent?
fluid
what kind of plot? Contour or XY-Plot? However, under the menu Derivatives you can find dp-dx, dp-dy and so on....maybe it is what you search... fluid
Old   November 12, 2007, 04:42
jrg
XY plot. The dpdx etc in Derivatives are actually density I think.
Old   November 12, 2007, 04:48
fluid
I don't really think so, but if you are sure.... Can't you check on the fluent manual? there's a section dedicated to explain what every voice in menu represents.. fluid
Fluent: Mesh Adaption based on Gradient enigma FLUENT 4 July 15, 2010 17:36
How to create an inlet with pressure gradient? val17lr FLUENT 5 July 13, 2010 15:15
How to give pressure inlet in Fluent Vijayaragavan Main CFD Forum 1 December 17, 2007 09:40
pressure outlet BC for Boussinesq with Fluent stephane Main CFD Forum 1 October 20, 2007 07:09
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 07:02
