November 6, 2007, 04:57 |
Velocity Inlet BC-VOF
hi I m modeling an open channel problem in fluent 6.1.22 I have two inlets specified as velocity inlets My question is that, at inlet i want only water to flow through the whole crossection not the air and water mixture... to do this shall i specify VOLUME FRACTION FOR AIR=0 at velocity inlet ?? THanks
November 11, 2007, 02:42 |
Re: Velocity Inlet BC-VOF
I think it's ok.You can choose the water as the primary phase,then set the Volume Fraction of the second phase to 0.
November 12, 2007, 01:42 |
thanks for the reply..\ can you please tell me that what can i do to specify the water depth at outlet...in vof i'm using fluent 6.1.2
November 12, 2007, 21:16 |
If you kown the depth of water at outlet,you can draw different outlet for air and water in gambit,then export to fluent6.1.Fluent 6.2 or 6.3 can specialfy the level of water easily by choose the "Open channel flow".
November 13, 2007, 01:43 |
Thanks... I'll try that
Display Modes | |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 16:35 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 08:20 |
[swak4Foam] Scale discrete inlet velocity profile with groovyBC | cboss | OpenFOAM Community Contributions | 1 | June 20, 2010 14:02 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 10:44 |
