-   -   UDF hook problem in command line mode. (http://www.cfd-online.com/Forums/fluent/46598-udf-hook-problem-command-line-mode.html)
Benlong November 12, 2007 15:41
I need to run a large problem in a remote computer server, which has no GUI. So I have to run in command line mode. For a CG-motion UDF, which hooks and works fine in a local machine with GUI. However if I hook the UDF in a command line, it give the following warning, even in the local machine in command line:
/define/dynamic-zones> creat Zone name/id [] 17 motion type: (stationary rigid-body deforming user-defined) enter motion type: [rigid-body] rigid-body profile/udf [] MovingZone::libudf cg location x (m) [1.0499994] cg location y (m) [0] cg location z (m) [0] cg orientation theta-x (deg) [0] cg orientation theta-y (deg) [0] cg orientation theta-z (deg) [0]
Warning: incorrect cg motion UDF movingzone::libudf on zone 17 (assuming no motion)
The UDF source code is : DEFINE_CG_MOTION(MovingZone, dt, vel, omega, time, dtime) {
Thread *t;
Domain *d;
real dv, CG[ND_ND], force[3], moment[3];
/* Check to see if there is data */
if (!Data_Valid_P ())
Message0("\n\nNo data->No mesh motion!!!\n\n");
return;
/* Reset velocities */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
vel[0] = 1.0; }
Can anybody give some help?
Benlong November 12, 2007 15:45
Re: UDF hook problem in command line mode.
sorry for there is no return in the above message, I paste it again:
Zone name/id [] 17
Warning: incorrect cg motion UDF movingshipzone::libudf on zone 17 (assuming no motion)
