how to make solution converge in supersonic flows |
November 20, 2007, 03:31 |
dear all:
i am currently using FLUENT to simulate external compressible transonic/supersonic flows. Coupled solution was chosen and Courant number needs to be set. Does anybody knows whether there are any tricks or techniques to define the parameters such as Courant number, relaxation factors etc. to make the residual decrease and solution converge? Thank you so much in advance. Regards |
November 21, 2007, 05:46 |
Re: how to make solution converge in supersonic fl
I think you can enter: Solve->controls->limits to adjust the limits to some suitable value. It maybe helpful for your convergence. Also you can use smaller Courant number and observe the residence curve. Hope this can help you. good luck. |
November 27, 2007, 15:41 |
try density based solver...(than pressure based one)...this work better for shock prediction in transonic and supersonic regime.....new fluent version having this option.....gud luck...
Numerical Solution of the Blunt Body in Supersonic Flow Problem | andres17 | Main CFD Forum | 19 | April 26, 2016 15:29 |
how to converge solution | nareshnkk | Main CFD Forum | 0 | October 13, 2010 04:14 |
What to do if solution doesn't converge | Sharon | FLUENT | 1 | February 15, 2007 00:40 |
a way to make lots of money quick and easy no lies | Dob | Main CFD Forum | 0 | October 10, 2006 16:45 |
STAR-CD and internal supersonic flows | Bart Prast | Main CFD Forum | 22 | December 10, 1999 16:38 |
