Gambit noise
Old   November 21, 2007, 10:50
Default Gambit noise
Stijn Vantieghem
Hi
We want to simulate a laminar pipe flow with our in-house code, but using a mesh created with GAMBIT (.msh-file). We use periodic boundary conditions for the streamwise direction. For this it is desireable that there is an exact translation between the grid points at both sides of the pipe. However, GAMBIT seems to add some random noise such that corresponding nodes don't coincide exactly. Is there any way to decrease this 'noise level' ?
Thanks in advance Stijn
Old   November 21, 2007, 23:21
Default Re: Gambit noise *NM*
Ganapathy
Old   November 21, 2007, 23:23
Ganapathy
Hey Stijn, You can link two faces or edges such that gambit creates the exact same mesh on both of them. There is a link button on the mesh panel under edges too.
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Boundary Layer Noise Source Model Andrew FLUENT 0 January 12, 2009 22:47
Turbo noise macro Barri CFX 0 May 21, 2008 09:26
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
