Continuity Convergence
Old   November 27, 2007, 10:57
Default Continuity Convergence
Marc
I'm having a problem that I've never experienced before. For some reason I'm struggling with continuity not converging. It's not diverging, but it's also not solving fully. I am toying with my solution schemes but cannot find a good mix of schemes. Most of my solution is being solved using QUICK, but currently my pressure is solved using the SIMPLE solver while my Pressure-Velocity coupling uses SIMPLEC with a skewness correction of 1.
Previously I've had one of my grids converge using a second-order pressure scheme and PISO with skewness correction for the p-v-coupling, but all subsequent grids have diverged with this method.
I'm waiting in queue to run another simulation using SIMPLE as my p-v-coupling solver too but it may be a while.
Are there any thoughts on how to get continuity to converge?
Thanks!
- Marc
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
