Replacing Zones
Old   December 4, 2007, 00:13
Default Replacing Zones
Steve
Dear all,
I have a mesh which is divided into several zones. I have a converged solution and now I wish to replace on of the zones with a finer mesh (identical geometry). I would like the current velocity field to be interpolated to the new mesh. Firstly, am I correct in thinking this is possible?
I have tried this and encountered a problem with the geometry scale. The original mesh was created in millimeters and then converted to meters in FLUENT. Hence when the mesh is replaced it is 1000 time too large. I seem to be able to work around this by scaling the mesh back to mm before replacing the zone. Is this the only workaround?
However, when I try the zone replace, FLUENT warns of a segmentation fault and crashes. I have tried a number of things, such as splitting the interface boundaries, without success.
Any suggestions will be gratefully received!
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 09:33
merge zones Domi FLUENT 2 May 3, 2019 13:15
[Other] how to extract cell zones by cgnsToFoam Ohbuchi OpenFOAM Meshing & Mesh Conversion 0 July 22, 2010 04:19
about seperating zones Bono FLUENT 1 October 8, 2005 06:08
Patch-Different values to different zones Pradeep FLUENT 0 April 26, 2005 08:50
