I can't view contour and vector
Some body know I have problem when I display contour or vector it's Show that " Floating point error: invalid number"
Re: I can't view contour and vector
This problem occurs only when you donot close the graphics window of fluent and give the command for displaying contour. First you please close all the graphics window(like window for iteration check, display grids etc.). then give command for dipaly contour . It will work
Thanks very much for reply, I close every window but it's not work ,maybe i set some thing worng with display?... Kiss chern
Can u write in details about ur problem. Did ur solution converged or ur viewing just after few iterations
Can u write in details about ur problem. Did ur solution converged or ur viewing just after few iterations. Could u check grids by display grids option
