Plot Y+ vs individual cell
Old   December 3, 2007, 06:10
Default Plot Y+ vs individual cell
Anhkien
Hi, Can anybody show me how to plot the Y+ vs individual cell please.
Thank you. Kien
Old   December 3, 2007, 07:20
Default Re: Plot Y+ vs individual cell
Louise
DO you want to plot along a curve?
Old   December 3, 2007, 07:51
Anhkien
hi, Yes, please show me. Thank you.
Old   December 3, 2007, 07:59
Louise
You have 2 possibilities, either you want to plot along a curve length or you want to plot along the coordinates of a certain curve. For both you have to go through making a curve from your object using iso-surface. Then you go to plot xy plot. If you want just curve length you go and change in x axis function and select that. (you can also have it on the y axis by changing from position on x axis to position on y axis in the options). If you want to plot with the coordinates you deselect position on x axis and you select x-coordinates (or y-coo. )in the x axis function (in the y axis...) and you select your curve in from surface. Hope that's all you need, if there is anything more, just ask.
Old   December 3, 2007, 08:07
Anhkien
thank you very much. I'll try.
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Finding Coordinates of individual cell in U.internalField() brosemu OpenFOAM Programming & Development 1 November 5, 2009 16:34
Reporting pressure at individual cell faces Shank FLUENT 0 September 11, 2007 12:24
Warning 097- AB Siemens 6 November 15, 2004 04:41
