December 4, 2007, 08:46 |
write a xy data file every timestep
We are using fluent to simulate the heat transfer in a heat exchanger. How can I write an xy data file every timestep to evaluate the average surface heat transfer? many thanks in advance!
December 5, 2007, 17:30 |
Re: write a xy data file every timestep
Try:
solve -> monitor -> surface then you could select what type of report you want ... integral, vertex-averaged etc ... If this isn't helpful, you could try to define a macro with exactly what you want to do and execute this macro at the end of every time-step. |
Display Modes | |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
UDF (write a data file) problem | lichun Dong | FLUENT | 2 | July 29, 2005 11:39 |
