Home > Forums > FLUENT
PLEASE, WHAT THIS mean Message (Error)
Old   December 7, 2007, 13:48
Default PLEASE, WHAT THIS mean Message (Error)
Emad
Dear; IF i read my file.msh in 3D from fluent 6.2 this message view, what mean blow message. PLEASE HELP THANK YOU EMAD
Reading "C:\Documents and Settings\Administrator\dd.msh"...
30602 nodes.
5100 mixed wall faces, zone 2.
1200 mixed wall faces, zone 3.
1200 mixed velocity-inlet faces, zone 4.
5100 mixed wall faces, zone 5.
7800 mixed wall faces, zone 6.
7500 mixed wall faces, zone 7.
2400 mixed pressure-outlet faces, zone 8.
300 mixed wall faces, zone 9. Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12.
Clearing partially read grid.
Error: Read aborted due to critical error. Error Object: ()
Error: Error reading "C:\Documents and Settings\Administrator\dd.msh". Error Object: #f
Old   December 8, 2007, 03:22
Default Re: PLEASE, WHAT THIS mean Message (Error)
k.baker
Not try to read the mesh file from "C:\Documents and Settings\Administrator\dd.mshcopy" try to read it from C:\> or any other drive this may solve the probelm.
with compliments K.Baker
Old   January 28, 2013, 16:11
Vinothkumar
Vinothkumar.s is on a distinguished road
i meshed a plain wing in gambit with T-grid, the domain was a bullet shaped. When i was tried to read in fluent the following problem has been arrived:
Reading "C:\Users\KSV\Desktop\2\default_id3632.msh"...
4805 nodes.
2430 mixed wall faces, zone 2.
5648 mixed wall faces, zone 3.
164 mixed pressure-outlet faces, zone 4.
1364 mixed velocity-inlet faces, zone 5.
Error Object: ()
Error: Error reading "C:\Users\KSV\Desktop\2\default_id3632.msh".
Error Object: #f
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Plz. help me someone on this problem
Vinothkumar.s is offline   Reply With Quote
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
