I can't view contour and vector
Old   December 3, 2007, 02:01
Default I can't view contour and vector
chern
Some body know I have problem when I display contour or vector it's Show that " Floating point error: invalid number"
Old   December 3, 2007, 04:20
Default Re: I can't view contour and vector
Jaysree
This problem occurs only when you donot close the graphics window of fluent and give the command for displaying contour. First you please close all the graphics window(like window for iteration check, display grids etc.). then give command for dipaly contour . It will work
Old   December 5, 2007, 21:41
chern
Thanks very much for reply, I close every window but it's not work ,maybe i set some thing worng with display?... Kiss chern
Old   December 10, 2007, 06:45
jaysree
Can u write in details about ur problem. Did ur solution converged or ur viewing just after few iterations
Old   December 10, 2007, 06:46
jaysree
Can u write in details about ur problem. Did ur solution converged or ur viewing just after few iterations. Could u check grids by display grids option
vector plots and contour plots do not match swati_mohanty FLUENT 1 August 26, 2010 05:53
Display velocity vector and contour in the same window lalula2 FLUENT 2 August 24, 2009 08:11
how to plot contour or vector with "GNUPLOT" ztdep Main CFD Forum 2 June 19, 2006 12:26
How to plot vel vector & contour on same plane? student CFX 7 May 12, 2006 08:15
Post: contour and vector Giovanni FLUENT 3 September 26, 2001 12:33
