How to give pressure inlet in Fluent
Old   December 12, 2007, 07:37
Default How to give pressure inlet in Fluent
Vijayaragavan
Dear Friends,
I am doing my project in Fluent,in Fluent software in pressure inlet boundary condition panel there is two column 1. Total gauge pressure 2. Intial\Sonic pressure.
My model is just a U tube pipe in that i want to know the pressure drop of a fluid, say my inlet condition is 2 bar. So in which column i have to give my pressure inlet, and how much i have to give pressure value. And i tried this many times but my result of static pressure drop is showing from 10e-12 to 5e5, and i dont know how to do it...........Please help me friends............
Old   December 12, 2007, 09:35
Default Re: How to give pressure inlet in Fluent
Ramesh.K
You should specify the total gauge pressure. 1.make operating pressure to zero and give the total gauge pressure to be 2 bar. 2. at out let u can specify outflow boundary condition
try this and see this may work out and initilize from all zones
bye
Old   December 13, 2007, 03:21
sastry
ya
the pressure inlet condition input varies from one proublem to other proublem
if the speed of medium is supersonic then only you need to enter second column (supersonic guage pressure)otherwise leave it
the reson for proublem u r phasing due to the outlet condition, if the flow is compressible,
can u send ur outlet boundary conditions
ok
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
pressure inlet & outlet. help ASAP Plz engahmed Main CFD Forum 0 June 13, 2010 15:34
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
How to give pressure inlet in Fluent Vijayaragavan Main CFD Forum 1 December 17, 2007 09:40
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 03:40
