Home > Forums > FLUENT
Wall Shear stress argument.
Old   December 13, 2007, 09:36
Default Wall Shear stress argument.
Dimitrios K. Fytanidis
Dear all,
i'm working on a project, in which i have to use the value of wall shear stress (wss) in a UDF. The main problem is that i can not find the wss argument name. Could anyone tell me the name of this particular variable? Of course, i have already unsuccesfully check the User guide.
Thank in advance for your variable help.
Old   December 14, 2007, 09:37
Default Re: Wall Shear stress argument.
szz
Hi Dimitrios,
with this command you can retrieve the wall shear stress of a certain face f, e.g. in a loop over all faces of a thread tf.
The result is a 3D-Vector (there should be one for 2D as well), here the components are stored separately:
F_x = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[0]; F_y = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[1]; F_z = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[2];
Hope this helps,
Regards szz
Old   December 14, 2007, 13:37
Thank you szz, But could you please tell me if these are stresses or forces. I check them and i found really strange results. Generally, I need the value of the component of Wall Shear Stress. Thank you in advance for your variable help.
Dimitrios
Old   December 15, 2007, 09:04
szz
sorry, it's the forces of course.
Dividing by the area should be possible for both the overall force and the components.
F_AREA(A, f, tf); area = NV_MAG(A);
I have found that although the value is accurate one has to be careful about the sign of the shear forces.
Regards szz.
Old   December 16, 2007, 10:33
Thank you szz!!!
Your help was really as usefull as valiable!!!
Regards,
Dimitrios
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 18:11
WALL SHEAR STRESS Andy CD-adapco 0 June 20, 2007 16:37
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
