December 13, 2007, 08:36 |
Wall Shear stress argument.
Dear all,
i'm working on a project, in which i have to use the value of wall shear stress (wss) in a UDF. The main problem is that i can not find the wss argument name. Could anyone tell me the name of this particular variable? Of course, i have already unsuccesfully check the User guide. Thank in advance for your variable help. Dimitrios K. Fytanidis |
December 14, 2007, 08:37 |
Re: Wall Shear stress argument.
Hi Dimitrios,
with this command you can retrieve the wall shear stress of a certain face f, e.g. in a loop over all faces of a thread tf. The result is a 3D-Vector (there should be one for 2D as well), here the components are stored separately: F_x = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[0]; F_y = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[1]; F_z = F_STORAGE_R_N3V(f,tf,SV_WALL_SHEAR)[2]; Hope this helps, Regards szz |
December 14, 2007, 12:37 |
Thank you szz, But could you please tell me if these are stresses or forces. I check them and i found really strange results. Generally, I need the value of the component of Wall Shear Stress. Thank you in advance for your variable help.
Dimitrios |
December 15, 2007, 08:04 |
sorry, it's the forces of course. Dividing by the area should be possible for both the overall force and the components. F_AREA(A, f, tf); area = NV_MAG(A); I have found that although the value is accurate one has to be careful about the sign of the shear forces. Regards szz. |
December 16, 2007, 09:33 |
Thank you szz!!!
Your help was really as usefull as valiable!!! Regards, Dimitrios |
relationship between wall shear stress and TKE | winter | FLUENT | 0 | December 11, 2007 17:11 |
WALL SHEAR STRESS | Andy | Siemens | 0 | June 20, 2007 16:37 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Re: About wall shear stress | Mike | FLUENT | 9 | November 17, 2003 14:41 |
